Activity Forums AJA Video Systems Io XT under Windows?
  • Io XT under Windows?
    Posted by Michaelmaier on June 16, 2014 at 9:45 am
    I run Win7 and I would like to buy the Io XT. Is anybody here using it with Windows? I know there are supposed to be drivers, but the marketing around the Io XT seems to be Mac centric.
    Also, I have no Thunderbolt in my computer. What is the most effective way to get a Thunderbolt connection in my computer to be used with Io XT?
    Or could I use the Apple Thunderbolt to Ethernet Adapter?
    Thanks.
    Matthew Sonnenfeld replied 12 years, 2 months ago 2 Members · 1 Reply
  • Matthew Sonnenfeld
    June 18, 2014 at 3:40 pm
    Hi Michael,
    The Io XT does work on windows but yes, most AJA marketing is geared towards Mac. That is because many of their devices are centered around ProRes and Mac users. Don’t forgot that AJA really got big as hardware for use with Final Cut Pro (legacy).
    Unfortunately though there is no way to connect an Io XT to a computer without Thunderbolt connection. The Apple adapter that you speak of is not simply a cable adapter and it requires the thunderbolt controller inside the computer to interpret the ethernet signal. An interesting thought for sure, though I would suggest that you look towards other options.
    What is the computer that you are trying to run? A PC laptop or desktop? If it is a desktop you can always get a Kona desktop card and when you upgrade to a machine with thunderbolt you can put in a thunderbolt PCIe chassis such as those available from Sonnet, Magma, or OWC. This will give you the flexibility to connect it to a laptop later and it will really be no different than an Io XT which is really a Kona3G card in an external thunderbolt chassis combined with pieces of the Kona breakout box.
    Co-President at fourB Productions, Inc.
    Blackmagic Cinema Camera, RED Scarlet-X
    2011 Macbook Pro 17″, 2.3 Ghz Quad Core, 16GB RAM
    2008 Mac Pro 2.6 Ghz 8 Core, 10GB RAM
    AJA IoXT, Blackmagic Intensity Pro, Blackmagic Mini Monitor
    Adobe Production Premium CC, Avid Media Composer 7, Final Cut Pro Studio 3
