Activity › Forums › AJA Video Systems › IO XT codec presets FCP 7
Posted by Tom Case on June 25, 2012 at 1:08 amI’m just building a new edit laptop and I use FCP 7. New hardware is pegasus R4, IO XT, and i7 17″ MBP. In FCP 7 setup I’m only finding baseline codecs in proresHQ, no aja ioxt proves LT, Proxy, or 422. Is there another download to add the other codecs? I only need LT for a press project I’m doing. I’m hoping they didn’t limit the codecs in FCP 7. (fingers crossed)
Tom Case replied 14 years, 2 months ago 5 Members · 8 Replies -
Jerry Hofmann
June 25, 2012 at 5:40 pmAren’t there some additional presets in a folder named that? might be called “AJA additional presets’… it would be in your user library’s FCP User prefs folder. If not, just spotlight “Additional Presets” and they’ll show up if they are there with that particular product.
If not, don’t see any reason you can’t create easy setups yourself…
Jerry
Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: https://blogs.creativecow.net/Jerry-Hofmann
Current DVD:
https://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX – Cinema Displays I have a 22″ that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
Aja Sales department
June 25, 2012 at 6:34 pmFinal Cut Pro 7 was a legacy software when the AJA Io XT product began shipping and therefore only a limited amount of presets were provided. Users may feel free to make any additional Easy Setups that they would like by using the provided Easy Setups as a starting point.
If you have questions about creating new Easy Setups that are specific to the AJA hardware, please feel free to contact AJA Technical Support via phone or email for assistance.
AJA Video Systems
+1 (530) 274-2048 Intl.
(800) 251-4224 US
sales@aja.com -
Wolfgang Schabhuettl
June 25, 2012 at 11:27 pmcan i use my kona3 settings for io XT in FCP7 ?
( my IO XT comes in 2 – 3 days )
Gary Adcock
June 26, 2012 at 2:25 pm[wolfgang schabhuettl] “can i use my kona3 settings for io XT in FCP7 ?
“No,
but you can use the easysetups that were included in the install for the IoExpress and then add the dual link /3G versions if needed. just uninstall the driver before installing the IoXT version.gary adcock
Studio37Post and Production Workflow Consultant
Production and Post Stereographer
Chicago, ILhttps://blogs.creativecow.net/24640
follow me on Twitter
@garyadcock -
Tom Case
June 27, 2012 at 9:27 pmThanks all for responses. The resolution was to create my own presets. I didn’t try this at first because I incorrectly assumed I wouldn’t be able to select the IO XT as input device. I’ve now created the presets I need and tested in/out/playback with them.
Thanks for your help.
