Activity Forums AJA Video Systems i/o set up question
  • i/o set up question
    Posted by Sbrand on June 5, 2007 at 10:21 pm
    I’m not sure if my output was connected correctly.
    It goes from the back of the G5 into the Panasonic monitor.
    Only one of the 3 connectors comes From the Mac center plug. It’s labeles SDI out 1.
    In the HD monitor, the connector SDI out 2 goes into the input.
    It seems odd that only l of the 3 connectors is used at each end, and they are both labeled “out.”
    Bob Zelin replied 19 years, 3 months ago 2 Members · 2 Replies
  • Bob Zelin
    June 5, 2007 at 10:27 pm
    REPLY –
    I have no idea of what you are talking about. “It goes from the back of the G5 into the Panasonic monitor” – what does this mean. You own an AJA I/O ? There are no connectors that go from teh back of the G5 into the Panasonic monitor. Do you mean the back of the I/O into the
    Panasonic monitor ? What output from the I/O, what input to the Panasonic monitor ? What Panasonic monitor do you own ?
    Only one of the 3 connectors comes From the Mac center plug. It’s labeles SDI out 1.In the HD monitor, the connector SDI out 2 goes into the input.
    REPLY – what is a MAC center plug ? Do you mean the AJA I/O ? You need to take AJA I/O SDI Out 1, and plug this into the SDI input of your Panasonic monitor (if you have an HD-SDI or SDI Panasonic monitor like the Panasonic BT-LH1700). If you give me model #’s, I can help you.
    REPLY – again, I have no idea of what you are talking about. The AJA I/O has 2 SDI outputs. One of these outputs will go to the SDI input of a Panasonic TV monitor. The AJA I/O has one SDI input, and 2 SDI outputs. Either of these 2 outputs can feed the Panasonic SDI input.
    Please be more specific – exact model #’s, and I can assist you.
    bob Zelin
  • Bob Zelin
    June 5, 2007 at 10:29 pm
    If you have a Kona LH or a Kona LHe, the SDI output of the Kona goes to the input of the Panasonic TV monitor (if it has an SDI input).
    Bob Zelin
