Activity › Forums › AJA Video Systems › I/O & Panasonic AJ-HD150 work?
Posted by Phillip Powell on July 18, 2007 at 8:38 pmPossible to use these two together? Trying to get best quality DVCPro into my system,
(FCutStudio II, MacTell Pro G5 Quad)Just wondering if any body’s doing this set up and how’d you hook in.
p2
Bob Zelin replied 19 years, 2 months ago 2 Members · 3 Replies -
Bob Zelin
July 18, 2007 at 9:48 pmwhat is your question – can you get the HD signal from a AJ-HD150 into an AJA I/O ? No. The AJ-HD150 has standard def outputs to feed the I/O, but it does not handle HD. Unless you are refering to the new I/O HD, which is not released yet.
Bob Zelin
Phillip Powell
July 18, 2007 at 11:35 pmSorry, know can’t do HD w/the I/o, just wondering if say, going standard def in to FinalCut from the AJ-HD150 thru the I/o would be better quality than FireWire in from Panasonic 1200A.
Just looking to get best quality from the boxes I’ve suddenly inherited in the new job.
p2
Bob Zelin
July 19, 2007 at 12:58 amif you are doing an HD job, obviously firewire from the AJ-HD1200A into FCP will look better, than standard def, from either the HD150 or HD1200A SDI output into the I/O. Most people who deal with HD prefer to work in HD, and then downconvert their output at the end. So even on a hi end example (HDCam 1080i job or Varicam 720p job), few are going to downconvert to SDI SD, just because the job will be delievered in SD (like on Beta). Most will edit and master the entire show in HD, and downcovert for delivery.
Bob Zelin
