Activity › Forums › AJA Video Systems › IO, New iMac and FW800
  • IO, New iMac and FW800
    Posted by Jamie Worsfold on September 7, 2006 at 11:52 am
    I see that the top of the range new iMac has a FW800 port on it.
    Would this cause any issues having my G-Tech FW800 drives running off that and having the IO into a FW400 port at the same time…?
    Jeremy Garchow replied 20 years ago 2 Members · 1 Reply
  • Jeremy Garchow
    September 7, 2006 at 6:06 pm
    You might be able to do it, but it’s not recommended. You should really separate the io and your firewire drives on a different bus which is impossible on the imacs.
    Jeremy
