Activity Forums VEGAS Pro I/O Manager Problem… Won’t show FileI/O in task manager…
  • I/O Manager Problem… Won’t show FileI/O in task manager…
    Posted by Jake Fredty on October 21, 2017 at 6:22 pm
    Hi my names is Jake.
    I have edited for about 2 years now. but here from 2 months ago i meet this problem… When i open sony vegas its freezes when its saying “creating I/O manager”
    I been search alot and i close to give up… I heard this site maybe can help ☺
    Last i looked in here i spotted that you could go into task manager and find vegas and find FileI/O manager and close it… the problem is that i dont have it under my vegas ☹
    Plz Help me.
    Jake Fredty replied 8 years, 11 months ago 3 Members · 4 Replies
  • Aaron Star
    October 21, 2017 at 7:57 pm
    I would list more information about your system specs, including sound card in use, GPU, CPU, memory type, system motherboard. “Speccy” is a good tool for this, and can export to a text format. Then post the summary section into the post.
    List your version and build number of Windows and Vegas.
    Make sure your Windows is up to date, and drivers up to date. Also make sure to include .net updates in windows update.
    If you know how, run memtes86+ (https://www.memtest.org/) and verify your memory has Zero errors across multiple runs.
    Run SFC /SCANNOW from an admin command prompt. This verifies the integrity of your windows core files. You should get a “Windows Resource Protection did not find any integrity violations.” response.
    Check your system DPC latency with:
    https://www.thesycon.de/eng/latency_check.shtml or https://www.resplendence.com/latencymon
    List your source media format (using “media info” app.) List your intended workflow from source, to timeline ,to export format.
    The last time I had this File IO error was way back, and my issue was with a really old high end Sound Blaster card. Once I removed it and the drivers, then switched to the newer on-board card the problem went away. That is why I suspect something with your configuration or workflow.
    The community is really good at helping people that list enough details about the problems they are having.
    Most of us did not put enough points into Divination, to read minds from a far.
  • Jake Fredty
    October 22, 2017 at 10:53 am
    Version 10.0.16299 Build 16299 and Build 177 in Sony vegas 15
    This is my Windows verison and my Speecy is https://gyazo.com/82f4ae7ddaa5fcf8c48f1b3fe29806a1
    Its won’t Run SFC/Scannow…
    Ps Can you do its more simpel im not so good at english so you lost me a lilltle bit…
    PS i updated my NVIDIA Driver. Still got the problem…
  • Ole Kristiansen
    October 22, 2017 at 11:33 am
    Hi Jake
    You can try to see if this fixes the problem !
    How To Fix Sony Vegas 14 (2017) Rendering Crash/File I/O Manager Fix
    https://www.youtube.com/watch?v=m-yo4GW0uJY
    Sony Vegas – How to fix “Creating file I/O manager”
    https://www.youtube.com/watch?v=r4lNbD3gIb4
    Best,
    Ole
  • Jake Fredty
    October 22, 2017 at 1:20 pm
    ITS WORKING AGAIN DUDE. LETS GO COWS !!!!!!!!!!!!!!!!
