Activity › Forums › AJA Video Systems › iO LA as stand-alone
Posted by Ron Thompson on September 20, 2005 at 2:27 pmThinking about the IOLA as a stand-alone addition with the KonaLH. Can anyone confirm whether or not all outputs are active when the unit is setup as a stand-alone box?
I think this IS the case with the IO box, but its not clear if the LA does this as well.Thanks
RonAja Sales department replied 21 years ago 4 Members · 6 Replies -
September 20, 2005 at 4:09 pmHi-
All of the outputs on the IoLA are always active, even in stand-alone mode. This is the case on all three Io models.
AJA Video Systems
(530) 274-2048 Intl.
(800) 251-4224 US
sales@aja.com -
Tony! Hulette
September 20, 2005 at 7:06 pm[Ron] “Thinking about the IOLA as a stand-alone addition with the KonaLH. Can anyone confirm whether or not all outputs are active when the unit is setup as a stand-alone box?
I think this IS the case with the IO box, but its not clear if the LA does this as well.”Personally, I would get the Kona 2 and Io LA, not the Kona LH and Io LA. With the Kona 2 you can up-convert analog video to HD (using the Io LA in-between the Kona 2 and the analog sources).
Tony!
Ron Thompson
September 20, 2005 at 8:24 pmThanks Tony!
Coming from a Cinewave, the LH is actually what I was waiting for from AJA. I really don’t need to up-convert SD video to HD. IF anything, my broadcast and corporate workflow require everything in SD. I also don’t work with any dual-link formats…so as I see it, I will be buying a card that is geared towards the HD post market, when I really don’t need it.
Right now 95% of my work is SD…5% HD.HD readiness is important though with these new HDV formats. But my bread and butter is in SD.
I would bet that 60%+ of the people who buy Kona2 boards are working in HD on at least 50% of their jobs.
However, in the future I can easily build another room based on the Kona2 if I need to and my work calls for it.Ron
Rob Alexander
September 20, 2005 at 9:36 pm[AJA Sales Department] “All of the outputs on the IoLA are always active, even in stand-alone mode. This is the case on all three Io models.”
does this include firewire? I’m wondering whether the IO could work as a convertor to feed AVID XPRESS pro (DV25) as well as FCP or do I need to look to convergent design for that??
September 21, 2005 at 1:45 amHi-
No, the Io’s will not work in this way. Our Firewire 400 connectors carry uncompressed data, for use with Final Cut Pro, etc.
AJA Video Systems
(800) 251-4224 US
sales@aja.com
