Activity Forums AJA Video Systems IO HD latency
  • IO HD latency
    Posted by Mack Truck on May 27, 2007 at 4:47 pm
    I was wondering about the latency of the new IO HD. AJA says “virtually no Firewire latency” : what do they mean exactly ? I have not been able to use the IO because of this latency: does the Firewire 800 makes it better ?
    Besides I already use Firewire 800 for a G-RAID : would that allow me to use the IO HD at the same time ?
    Dave Garcia replied 19 years, 3 months ago 4 Members · 4 Replies
  • John Ladle
    May 28, 2007 at 3:22 am
    i would assume lower latency is due to FW800 protocol and maybe some engineering feats, AJA tightened up the IO considerably over the 4 years of development. As far as the FW 800 of the IOHD and the FW400 of the IO series, the bitrates stay the same over a larger pipe. Prores 422 HQ HD formats are merely 220megabits and as everyone is gettting to know, that equates the bitrate of full faster 10 bit high quality HD application codec with that of uncompressed SD.
    SIDENOTE or maybe the point:
    you are not supposed to use firewire drives on the same bus with the IO, IOHD or most other video firewire device that captures and does not transfer. you can use the PC or PCI-express 34 slot for the storage device be it firewire 400, 800 or eSata.
  • Mack Truck
    May 28, 2007 at 5:48 am
    [uncompressed] “you are not supposed to use firewire drives on the same bus with the IO, IOHD or most other video firewire device that captures and does not transfer. you can use the PC or PCI-express 34 slot for the storage device be it firewire 400, 800 or eSata.”
    So what would be the IO HD setup for a MacBook Pro (firewire 400 drive ?). Thanks.
  • Szumlins
    May 28, 2007 at 1:42 pm
    [Mack Truck] “So what would be the IO HD setup for a MacBook Pro (firewire 400 drive ?). Thanks.”
    You would get an Express34 firewire card or eSATA card to support your storage on a Macbook Pro
    -Mike
  • Dave Garcia
    May 30, 2007 at 4:53 am
    …or capture onto the 2 gigs of harddrive space left on your system disk…
    (joke)
