Activity Forums AJA Video Systems IO Hd Delay
  • Jorge Goizueta
    July 3, 2008 at 7:28 pm
    Im out of the office as soon i get back i send you the info
  • Lawrence Shea
    July 3, 2008 at 8:41 pm
    Thanks Jeremy. Here is my info.
    Lawrence
    Hardware ID: IoHD (0x10224000) S/N IH002423
    VideoProc Bit file: 2007/12/04 13:00:16 (DownConvert)
    /Library/QuickTime:
    5.1.2 – AJACodec.component
    5.1.2 – AJADigitizer.component
    5.1.2 – AJAMuxer.component
    5.1.2 – AJAUncompressedCodec.component
    5.1.2 – AJAVideoOutput.component
    5.1.2 – AJAVideoOutputClock.component
    5.1.2 – AJAVideoOutputCodec.component
    1.5 – FCP Uncompressed 422.component
    1.4 – DVCPROHDCodec.component
    1.2 – AppleIntermediateCodec.component
    1.4 – AppleHDVCodec.component
    1.0.2 – AppleProRes422.component
    /Applications:
    5.1.2 – AJA ControlPanel.app
    /Applications/AJA Utilities:
    5.1.2 – AJA Conflict Checker.app
    5.1.2 – AJA Data Rate Calculator.app
    5.1.2 – AJA DPXToQTTranslator.app
    5.1.2 – AJA IoHDUpdater.app
    5.1.2 – AJA QTToDPXTranslator.app
    5.1.2 – AJA System Test.app
    5.1.2 – AJA TV.app
    5.1.2 – AJA Uninstaller.app
    /System/Library/Extensions:
    5.1.2 – AJAIoHD.kext
    /Library/LaunchAgents:
    11/20/2007 18:10 – com.aja.ajaagent.plist
    /Library/Application Support/AJA/AJAAgent:
    06/05/2008 19:08 – AJAAgent
    /Library/Application Support/Final Cut Pro System Support/Plugins:
    06/05/2008 19:12 – AJA Kona RT Enabler
    /Library/Application Support/Final Cut Pro System Support/Custom Settings/IoHD Easy
    Setups:
    09/28/2007 17:47 – AJA IoHD- 1080i 25 Apple ProRes 422 (HQ).fcpre
    09/28/2007 17:47 – AJA IoHD- 1080i 25 Apple ProRes 422.fcpre
    09/28/2007 17:47 – AJA IoHD- 1080i 25 Apple ProRes to 10 Bit Uncompressed.
    09/28/2007 17:47 – AJA IoHD- 1080i 25 Apple ProRes to 8 Bit Uncompressed.fc
    11/08/2007 18:10 – AJA IoHD- 1080i 25 Apple ProRes to DVCProHD.fcpre
    09/28/2007 17:47 – AJA IoHD- 1080i 29.97 Apple ProRes 422 (HQ).fcpre
    09/28/2007 17:47 – AJA IoHD- 1080i 29.97 Apple ProRes 422.fcpre
    09/28/2007 17:47 – AJA IoHD- 1080i 29.97 Apple ProRes to 10 Bit
    Uncompressed.fcpre
    09/28/2007 17:47 – AJA IoHD- 1080i 29.97 Apple ProRes to 8 Bit
    Uncompressed.fcpre
    11/08/2007 18:10 – AJA IoHD- 1080i 29.97 Apple ProRes to DVCProHD.fcpre
    09/28/2007 17:47 – AJA IoHD- 1080psf 23.98 Apple ProRes 422 (HQ).fcpre
    09/28/2007 17:47 – AJA IoHD- 1080psf 23.98 Apple ProRes 422.fcpre
    09/28/2007 17:47 – AJA IoHD- 1080psf 23.98 Apple ProRes to 10 Bit
    Uncompressed.fcpre
    09/28/2007 17:47 – AJA IoHD- 1080psf 23.98 Apple ProRes to 8 Bit
    Uncompressed.fcpre
    11/08/2007 18:10 – AJA IoHD- 1080psf 23.98 Apple ProRes to DVCProHD.fcpre
    09/28/2007 17:47 – AJA IoHD- 720p 23.98 Apple ProRes 422 (HQ) Varicam.fcp
    09/28/2007 17:47 – AJA IoHD- 720p 23.98 Apple ProRes 422 Varicam.fcpre
    10/01/2007 12:06 – AJA IoHD- 720p 23.98 Apple ProRes to 10 Bit Uncompress
    Varicam.fcpre
    09/28/2007 17:47 – AJA IoHD- 720p 23.98 Apple ProRes to 8 Bit Uncompressed
    Varicam.fcpre
    11/08/2007 18:10 – AJA IoHD- 720p 23.98 Apple ProRes to DVCProHD
    Varicam.fcpre
    09/28/2007 17:47 – AJA IoHD- 720p 25 Apple ProRes 422 (HQ).fcpre
    09/28/2007 17:47 – AJA IoHD- 720p 25 Apple ProRes 422.fcpre
    09/28/2007 17:47 – AJA IoHD- 720p 25 Apple ProRes to 10 Bit Uncompressed.f
    09/28/2007 17:47 – AJA IoHD- 720p 25 Apple ProRes to 8 Bit Uncompressed.fc
    11/08/2007 18:10 – AJA IoHD- 720p 25 Apple ProRes to DVCProHD.fcpre
    11/16/2007 18:12 – AJA IoHD- 720p 50 Apple ProRes 422 (HQ).fcpre
    11/16/2007 18:12 – AJA IoHD- 720p 50 Apple ProRes 422.fcpre
    11/16/2007 18:12 – AJA IoHD- 720p 50 Apple ProRes to 10 Bit Uncompressed.f
    11/16/2007 18:12 – AJA IoHD- 720p 50 Apple ProRes to 8 Bit Uncompressed.fc
    11/16/2007 18:12 – AJA IoHD- 720p 50 Apple ProRes to DVCProHD.fcpre
    09/28/2007 17:47 – AJA IoHD- 720p 59.94 Apple ProRes 422 (HQ).fcpre
    09/28/2007 17:47 – AJA IoHD- 720p 59.94 Apple ProRes 422.fcpre
    09/28/2007 17:47 – AJA IoHD- 720p 59.94 Apple ProRes to 10 Bit
    Uncompressed.fcpre
    09/28/2007 17:47 – AJA IoHD- 720p 59.94 Apple ProRes to 8 Bit
    Uncompressed.fcpre
    11/08/2007 18:10 – AJA IoHD- 720p 59.94 Apple ProRes to DVCProHD.fcpre
    09/15/2007 17:21 – AJA IoHD- NTSC 10 Bit Uncompressed.fcpre
    09/15/2007 17:21 – AJA IoHD- NTSC 8 Bit to DV.fcpre
    09/15/2007 17:21 – AJA IoHD- NTSC 8 Bit to DVCPro50.fcpre
    09/19/2007 18:11 – AJA IoHD- NTSC 8 Bit Uncompressed.fcpre
    09/28/2007 17:47 – AJA IoHD- NTSC Apple ProRes 422 (HQ).fcpre
    09/28/2007 17:47 – AJA IoHD- NTSC Apple ProRes 422.fcpre
    09/17/2007 18:44 – AJA IoHD- PAL 10 Bit Uncompressed.fcpre
    09/15/2007 17:21 – AJA IoHD- PAL 8 Bit to DV.fcpre
    09/15/2007 17:21 – AJA IoHD- PAL 8 Bit to DVCPro.fcpre
    09/15/2007 17:21 – AJA IoHD- PAL 8 Bit to DVCPro50.fcpre
    09/15/2007 17:21 – AJA IoHD- PAL 8 Bit Uncompressed.fcpre
    09/28/2007 17:47 – AJA IoHD- PAL Apple ProRes 422 (HQ).fcpre
    09/28/2007 17:47 – AJA IoHD- PAL Apple ProRes 422.fcpre
    Possible conflicting QuickTime components:
    No conflicting files found.
  • Jorge Goizueta
    July 3, 2008 at 10:29 pm
    Hi jeremy here are my spec
    Jorge
    /Library/QuickTime:
    /Applications:
    5.1.2 – AJA TV.app
    /Library/Application Support/Final Cut Pro System Support/Custom Settings/IoHD Easy Setups:
    09/28/2007 17:47 – AJA IoHD- 1080i 25 Apple ProRes to 10 Bit Uncompressed.fcpre
    09/28/2007 17:47 – AJA IoHD- 1080i 25 Apple ProRes to 8 Bit Uncompressed.fcpre
    09/28/2007 17:47 – AJA IoHD- 1080i 29.97 Apple ProRes to 10 Bit Uncompressed.fcpre
    09/28/2007 17:47 – AJA IoHD- 1080i 29.97 Apple ProRes to 8 Bit Uncompressed.fcpre
    09/28/2007 17:47 – AJA IoHD- 1080psf 23.98 Apple ProRes to 10 Bit Uncompressed.fcpre
    09/28/2007 17:47 – AJA IoHD- 1080psf 23.98 Apple ProRes to 8 Bit Uncompressed.fcpre
    09/28/2007 17:47 – AJA IoHD- 720p 23.98 Apple ProRes 422 (HQ) Varicam.fcpre
    10/01/2007 12:06 – AJA IoHD- 720p 23.98 Apple ProRes to 10 Bit Uncompressed Varicam.fcpre
    09/28/2007 17:47 – AJA IoHD- 720p 23.98 Apple ProRes to 8 Bit Uncompressed Varicam.fcpre
    11/08/2007 18:10 – AJA IoHD- 720p 23.98 Apple ProRes to DVCProHD Varicam.fcpre
    09/28/2007 17:47 – AJA IoHD- 720p 25 Apple ProRes to 10 Bit Uncompressed.fcpre
    09/28/2007 17:47 – AJA IoHD- 720p 25 Apple ProRes to 8 Bit Uncompressed.fcpre
    11/16/2007 18:12 – AJA IoHD- 720p 50 Apple ProRes to 10 Bit Uncompressed.fcpre
    11/16/2007 18:12 – AJA IoHD- 720p 50 Apple ProRes to 8 Bit Uncompressed.fcpre
    09/28/2007 17:47 – AJA IoHD- 720p 59.94 Apple ProRes to 10 Bit Uncompressed.fcpre
    09/28/2007 17:47 – AJA IoHD- 720p 59.94 Apple ProRes to 8 Bit Uncompressed.fcpre
  • Ken Botelho
    July 4, 2008 at 1:54 am
    Is it an A/V sync issue or just a delayed output?
  • Lawrence Shea
    July 4, 2008 at 10:16 am
    It’s an intermittent sync issue with audio and video.
  • Lawrence Shea
    July 4, 2008 at 10:18 am
    It’s a sync issue with audio and video.
  • Gary Adcock
    July 4, 2008 at 1:28 pm
    [Jorge Goizueta] “Hi jeremy here are my spec “
    the build of the driver is incorrect- the 5.1.2 driver is ONLY for users running leopard- and your specs said that you were on 10.4.11
    from the aja site
    This driver version has the same feature set as version 5.1.1 and is only meant to address possible issues for users working with Io HD when operating under OS X 10.5.3.
    this will also mean that you have to update the firmware in the unit again also.
    gary adcock
    Studio37
    HD & Film Consultation
    Post and Production Workflows
    Inside look at the IoHD
  • Ken Botelho
    July 4, 2008 at 4:40 pm
    Ok, A/V sync is entirely different from FireWire delayed output. And I can tell you I also have been struggling with this issue on 3 different ioHD boxes since the initial release, and its not caused by the driver/firmware version either.
    A few steps that I always take to help with the sync issues until AJA takes can address this problem.
    – Check that all equipment is properly Genlocked, including the ioHD
    – Verify AJA audio output/input is not selected in the “OS X system preferences” (change to line or built-in input/output)
    – Be sure to power up AJA before powering up computer
    – Attach AJA to your system bus and not a firewire ExpressCard or Firewire pci card
    – Recapture any previously captured video to verify its capturing in sync
    – Playback from timeline to verify A/V playback sync
    – At last test your quicktime playback with AJA VTR Xchange, to rule out any Final Cut configuration issues
  • Jeremy Garchow
    July 4, 2008 at 5:22 pm
    Yes, Lawrence that is a seprate issue and you should start a new thread for that as Jorge is having different problems.
    Jeremy
  • Lawrence Shea
    July 5, 2008 at 12:41 pm
    Thank you all for your help. Sorry for the confusion.
Page 3 of 3
