Activity Forums AJA Video Systems Io HD Absent Audio
  • Io HD Absent Audio
    Posted by Jason Cox on July 2, 2008 at 9:02 pm
    Mac Pro, 8X3.2GHz, 16GB RAM, OS 10.5.3, FCP 6.0.3
    I am using the Io HD to capture from a DVCPRO 50 deck. I have complete machine control and can view the video in FCP but I am unable to capture audio or get any type of meter reading in FCP.
    I do get a reading on the Io box, I have changed my settings in the AJA control panel, uninstalled and reinstalled the Io software and still no audio. I even tried deleting my FCP user preferences and still no luck. The issue seams to be somewhere between the Io and FCP but I am not sure what is going on.
    Note: I have been using the Panasonic AJ-PCD20 drive to ingest my P2 media into FCP for the past couple of months and have had no need for the Io or the DVCPRO 50 deck would this have created some type of conflict?
    Please Advise!
    Ryan Rivard replied 17 years, 10 months ago 4 Members · 4 Replies
  • Jeremy Garchow
    July 2, 2008 at 9:16 pm
    [Jason Cox] “Note: I have been using the Panasonic AJ-PCD20 drive to ingest my P2 media into FCP for the past couple of months and have had no need for the Io or the DVCPRO 50 deck would this have created some type of conflict?”
    It shouldn’t.
    As long as you have the proper inputs selected in the control panel: In the Log and capture window, make sure your audio tracks are selected under the Clip Settings tab.
    Also, make sure you have the latest ioHD drivers installed. Uninstall your older ones first. The latest is v5.1.2.
    https://www.aja.com/html/support_Io_swd.html
    Jeremy
  • Ryan Rivard
    November 3, 2008 at 7:32 pm
    Jason,
    By updating the drivers did that take care of the problem? I’ve got the same thing going on here.
    Ryan
  • Ryan Rivard
    November 3, 2008 at 7:51 pm
    Thanks, I’ll give that a try.
  • Gary Adcock
    November 3, 2008 at 8:07 pm
    [Ryan Rivard] “By updating the drivers did that take care of the problem? I’ve got the same thing going on here. “
    its a firmware issue- make sure that you have also run the IoHD firmware updater.
    gary adcock
    Studio37
    HD & Film Consultation
    Post and Production Workflows
    Inside look at the IoHD
