Activity › Forums › AJA Video Systems › IO firmware update
  • IO firmware update
    Posted by Francois Driessen on August 3, 2006 at 3:47 am
    Hi there. Just to make sure I’m not missing anything.
    My IO control panel quits immediately when fired up after installing FCP 5.1. Tried going with AJA Io v3.O with no difference.
    I ran the 22-27 firmware installer for IO, but that made no difference either. Then reverted back to 21-26 to see if that changes anything which it did not.
    The updater window states: current IO version 4-4 no matter which one I installed (I have cycled the power and restarted the Mac). Just checking that that refers to the IO model? and not the firmware (in which case it never got updated). Any advice?
    Anyone having the same quitting issue?
    Francois
    >- e y e f l a m e .tv –< https://eyeflame.tv
    Bob Zelin replied 20 years, 1 month ago 3 Members · 3 Replies
  • Francois Driessen
    August 3, 2006 at 3:58 am
    OK. Quit pain solved: An iSight plugged into the front FW port. Removing it solved the quitting. Still wondering about that 4-4 thing, though? In system profiler the sub units look as follows:
    Io Unit:
    Unit Software Version: 0x20
    Unit Spec ID: 0xA27
    Io Unit:
    Unit Software Version: 0x22
    Unit Spec ID: 0xA27
    Io Unit:
    Unit Software Version: 0x11
    Unit Spec ID: 0xA27
    Io Unit:
    Unit Software Version: 0x24
    Unit Spec ID: 0xA27
    Guess that implies the 22-27 version is in fact installed?
    Francois
  • Jeremy Garchow
    August 3, 2006 at 5:12 am
    Just in case, i would uninstall and reinstall the drivers/control panel.
    Jeremy
  • Bob Zelin
    August 3, 2006 at 11:08 pm
    and remember – don’t plug ANYTHING ELSE EVER AGAIN into your firewire port. This means NO FIREWIRE 400 DRIVES while you are using the AJA I/O.
    bob ZElin
