Activity Forums AJA Video Systems IO doesn’t seem to Uninstall
  • IO doesn’t seem to Uninstall
    Posted by Dave Martin on January 15, 2008 at 10:30 am
    Hi Guys
    So I’m trying to uninstall the IO drivers/prefs etc so I can install my new IO HD. I downloaded the uninstaller app and ran it. It said it worked but my presets were still listed in FCP. So I ran it again…it found three other files to delete. I rebooted and…the fcp presets are still there.
    Is this normal? Has anyone else run into this?
    Thanks…
    Dave Martin
    – MacPro – MacBook Pro –
    Gary Adcock replied 18 years, 7 months ago 2 Members · 3 Replies
  • Gary Adcock
    January 15, 2008 at 1:58 pm
    [Dave Martin] “So I’m trying to uninstall the IO drivers/prefs etc so I can install my new IO HD. I downloaded the uninstaller app and ran it. It said it worked but my presets were still listed in FCP. So I ran it again…it found three other files to delete. I rebooted and…the fcp presets are still there. “
    you are running the AJA un-installer that was with the older version of the software?
    FCP prefs are not reset until the reinstall…..
    gary adcock
    Studio37
    HD & Film Consultation
    Post and Production Workflows
    Inside look at the IoHD
  • Dave Martin
    January 15, 2008 at 4:18 pm
    Thanks Gary
    I downloaded the uninstaller straight from AJA.com. Sounds like this is normal and they’ll be gone once I install the IOHD?
    BTW-may I ask your procedure when you switch back and forth between IOHD and IO?
    Thanks again Gary…
    Dave Martin
  • Gary Adcock
    January 16, 2008 at 4:33 pm
    [Dave Martin] “I downloaded the uninstaller straight from AJA.com”
    all aja driver installs include an uninstaller, in the folder where the apps are stored. downloading a newer version will not remove all of the files- every version is different, that is why the files were no properly removed.
    “sk your procedure when you switch back and forth between IOHD and IO? “
    Switching between drivers.
    I uninstall using the current drivers uninstaller
    ( found in Applications >AJA Utilities and I keep the icon in my dock for simplicity)
    then run the installer for the replacement driver and reboot.
    gary adcock
    Studio37
