Activity › Forums › Apple Final Cut Pro Legacy › IO Control Panel/Log and capture issues
  • IO Control Panel/Log and capture issues
    Posted by Jeff Surgeon on August 20, 2005 at 4:34 am
    I try to log and capture my video sdi and my audio analog.
    I make those setting in the IO Control panel, call up log and capture, and I get no audio. The settings on the control panel have changed back to imbedded SDI audio. I have been editing for 4 weeks now, this is the first issue with this. I am at a stand still now. Should I uninstall the control panel, or what?
    Please help.
    Jeff
    Doug Olin replied 21 years, 1 month ago 3 Members · 2 Replies
  • Gary Adcock
    August 21, 2005 at 2:15 pm
    [Jeff Surgeon] “I try to log and capture my video sdi and my audio analog.
    I make those setting in the IO Control panel, call up log and capture, and I get no audio.”
    the Io control panel does not control capture in FCP the easy setups do that.
    what settings are you using in what version of the software.
    you may need to do a custom set up FCP to override the easy setup in for the audio/
    gary adcock
    Studio37
    HD and Film Consultation
  • Doug Olin
    September 3, 2005 at 3:24 pm
    In the setup you choose make sure SDI video is selected with analog audio. You can save the custom setup with a name that’s easy to spot like “8 bit SDI analog audio” or something like that.
    Doug Olin
