Activity Forums AJA Video Systems I/O audio issue
  • I/O audio issue
    Posted by Christian Vorbeck on November 10, 2005 at 7:48 pm
    Hi
    When I playback thru the Aja I/o the volume goes way up, but on the timeline there are no peaks. (and the audio tracks are created on a professional studio). What is this?
    In the meantime I’m lowering the volume in the timeline, but how can I solve this?
    Direct output from AJA I/O to external recorder or external monitor, no console in between. Do I need to get a console?
    Tnaks
    Christian
    Thanks Experts
    Christian
    Lee Berger replied 20 years, 10 months ago 2 Members · 1 Reply
  • Lee Berger
    November 10, 2005 at 9:29 pm
    Christian:
    If you are talking about the difference in level between the output of your Mac and the Io, there is a big difference. The Mac’s audio out is at consumer level around -10 dbf and the Io is at professional levels, selectable between +18 and +24dbf. How is your system configured? Does the Io feed your deck directly? Does your deck have professional balanced inputs? Does the deck then feed your monitors? In my system I use an 8-input mixer with balanced inputs for my two decks the Io. I also feed the output from my Mac into a couple of unbalanced inputs. The mixer then feeds the decks (for analog recording) and a powered speaker system for monitoring.
    Lee
