Activity › Forums › AJA Video Systems › IO as a standalone box
Posted by Mark Cookman on May 9, 2005 at 1:18 pmIs it possible to configure a Final Cut system so that the IO is just an external device?
I would like to use an existing (sdi only) card on my workstation but feed various signals to it via the IO and its control panel.
regards
MarkAja Sales department replied 21 years, 4 months ago 2 Members · 5 Replies -
May 9, 2005 at 3:58 pmHi-
Yes! Here is an earlier Cow post that describes it:
https://www.creativecow.net/forum/read_post.php?postid=111375155576545&forumid=150&highlight=
So, yes, the Io can be used as a stand-alone frame-sync to feed analog and/or digitial signals to anything you like…including the use you asked about, feeding an SDI only card in your FCP setup.
Please feel free to contact us if you addtional questions.
Thank you,
AJA Video Systems
(530) 274-2048
sales@aja.com -
Mark Cookman
May 10, 2005 at 12:20 pmhe he …. thats me on the end of that thread asking same question!
I read the material and thought I understood that you cannot have FCP and the control panel running at the same time because of driver problems.
My theory is to somehow de-install the IO drivers from FCP and thus use the control panel and IO to feed embedded SD to a PCI card (running FCP). …….Would this work?
I will try it but first need to know how to deinstall the FCP/IO drivers.
thanks
Mark -
May 10, 2005 at 3:58 pmHi Mark-
The Io drivers and the Control panel are separate pieces of software, so yes, you can install just the Control Panel app. This would then allow you to operate FCP and the Io Control Panel at the same time.
AJA Video Systems
(530) 274-2048 Intl.
(800) 251-4224 US
sales@aja.com -
Mark Cookman
May 11, 2005 at 8:42 pmThanks for that confirmation – how can i de – install the driver from my current system?
May 11, 2005 at 9:02 pmHi-
Please contact our support department, as we try to not offer technical support on public forums.
support@aja.com
(530) 271-3190Thank you,
AJA Video Systems
(800) 251-4224 US
sales@aja.com
