Activity › Forums › AJA Video Systems › IO and Tiger
David Massachi
June 16, 2005 at 5:15 pmWhat exactly do you mean by “23.98 frame rate support?” Will I be able to capture through any of the inputs and remove standard 2:3 pulldown? What capture codecs will this work for (UN8 and/or DV25)? Will I be able to play out to tape/monitor through any of the outputs and add standard 2:3 pulldown on the fly? What timeline codecs will this work for?
My system:
G4 Dual 1.42 GHz
2 GB RAM
OS 10.3.9
FCP 4.5
QT Pro 6.5.2 (and QT Player 7.0.1)
Uncompressed 8-bit 4:2:2 via SDI to/from DVW-A500
Xserve RAIDmassachi
