Activity Forums AJA Video Systems Io and Powerbook
  • Io and Powerbook
    Posted by Christopher Tay on October 12, 2005 at 7:04 pm
    If I use a Firewire800 drive on the Firewire800 port of the Powerbook, can I attach the Io to the Fire400 port and be able to capture 8bit uncompressed, assuming the Firewire800 drive can deliver the bandwidth ?
    -chrispy
    Aja Sales department replied 20 years, 11 months ago 4 Members · 3 Replies
  • Mark Kruger
    October 13, 2005 at 3:15 pm
    I’ve used a PCMCIA Firewire 800 card for the drives. I used 2 striped together and had no problem.
  • Ed Dooley
    October 14, 2005 at 2:02 pm
    Do a search in this forum’s archive. There are lots (and lots) of posts about it. The IO uses *all* the bandwidth of the FW400 port (or
    enough of it to make it unusable for media drives on the FW800 port. And the FW400 and 800 are on the same buss! Get the FW800 cardbus card.
    Ed
    [chrispy] “If I use a Firewire800 drive on the Firewire800 port of the Powerbook, can I attach the Io to the Fire400 port and be able to capture 8bit uncompressed, assuming the Firewire800 drive can deliver the bandwidth ?
  • Aja Sales department
    October 14, 2005 at 4:27 pm
    Hi-
    You can also check our Configuration Guide:
    https://www.aja.com/pdfs/AJA_config_guide_web.pdf
    This configuration is detailed there.
    Thank you,
    AJA Video Systems
    (530) 274-2048 Intl.
    (800) 251-4224 US
    sales@aja.com
