Activity › Forums › AJA Video Systems › IO and HD what is the best solution?
Posted by Rainer Wirth on May 31, 2007 at 3:14 pmI’m thinking of going HD: I have an IO and its working very good.
What are your suggestions adding HD?Rainer Wirth
Russell Lasson replied 19 years, 3 months ago 5 Members · 10 Replies -
Russell Lasson
May 31, 2007 at 3:37 pmIf you want to finish in ProRes, the IO HD will be a great box.
If you need uncompressed, then you need super fast drives and I’d suggest the Kona LH or Kona 3.
How are you getting your HD footage? Is it 1080i or 720p? Is it 23.98 or 60P? What are you finishing to? (Answer these questions if you want more feedback)
-Russ
Rainer Wirth
May 31, 2007 at 5:08 pmThanks for your input.
Mainly I’m working on SD. But sometimes an HD shows up. I’ve got an Panasonic HD Control monitor(Makes SD as well) and one Bus is still free. Storage is no problem, because I#ve got an Xserve Raid and a SCSI Raid. I still want to continue with my IO, because it is very good and reliable. The card has to work with the IO together. The AJA Tech recommended the Kona LH. Mainly I got P2 HD Material, so I need a monitoring. If the customer still wants a Tape, I can borrow a HDCAM or HDDVCPRO. Normally people want to have the feeling of HD, because a SD DVD stands at the end. How do you downconvert?
Because this seems to me a major point in loosing quality what we are fighting for.Rainer
Russell Lasson
May 31, 2007 at 5:54 pmIf you get a Kona LH, what do you need the IO for?
[Rainer Wirth] “How do you downconvert?”
I created my own settings in compressor after doing several tests. I downconvert to 10-bit uncompressed (soon to use ProRes) then deliver it to our DVD authoring company. But sometimes different footages needs some adjustments (especially if there is a lot of text).
As much as every one hates it, compression is an science, not a setting.
-Russ
Jeremy Garchow
May 31, 2007 at 6:31 pmIf you have an full blown io, I’d go for the Kona3 (or KOna 3X). Or you can simply wait for the ioHD and work in ProRes.
Jeremy
Bob Zelin
May 31, 2007 at 8:45 pmthis is correct – the Kona 3.
The “AJA Tech” that recommended the LH (when you already own the I/O) is not an AJA Tech. Get the Kona 3. The perfect compliment to the I/O.Bob Zelin
Jeff Heywood
June 4, 2007 at 4:19 pmJust tacking on to the end of this because I have a similar question. All my footage is hdv or p2. Mostly p2. We’re getting brand new macpro’s and final cut studio 2.
Is there a card I need? We’re delivering through digital files, and we don’t do any analogue capture or capture from decks other than our HDV deck.
The big question is monitoring and acceleration of DVCPROHD and HDV. We’re trying to keep costs in line, and that’s why I’m asking instead of just throwing money at the question and buying things.
I was thinking of the mxo for monitoring, or spending a bit more and getting an LH for basic acceleration and monitoring. What’s the best cheap route to go?
The main thing we’re trying to build is hiccup free workflow.
Russell Lasson
June 4, 2007 at 4:21 pmWhat video monitor are you going to be using? Are you going to be color correcting?
-Russ
Jeff Heywood
June 4, 2007 at 4:27 pmWe don’t have a monitor yet. We’re looking at consumer HDTV. We deliver to a collection of 32 LCD’s, Plasma’s, and HD projectors. None of them are calibrated. So we’re all over the map. For that reason, I’m not putting a lot of pressure on our monitoring. I just want it to work well enough that we can get a good idea of focus, and the impact of seeing things on a larger screen. We’ll be doing a fair amount of colour work but, again, it’s for delivery to our screens, not for broadcast clearance.
Russell Lasson
June 4, 2007 at 4:33 pmI would suggest the Blackmagic Intensity cards. The you could purchase consumer HDTVs that you like and connect it directly over HDMI. They’re inexpensive cards which is nice.
I would describe your color correcting needs as non-crucial. With a little testing, you’ll be able to make decent decisions with this set up.
-Russ
