Activity Forums AJA Video Systems IO and D9
  • IO and D9
    Posted by Alan Lacey on July 27, 2005 at 4:59 pm
    I’m in the process of installing an IO in a JVC D9 suite and am having problems with digital audio.
    The deck in question is a PAL D-750 without embedded audio. Everything else works fine apart from the EBU return to the deck.
    Is anyone else out there using separate AES/EBU audio with their SDI feeds to D9 and experiencing any trouble?
    Thank you
    Alan (London)
    Alan Lacey replied 21 years ago 2 Members · 4 Replies
  • Alan Lacey
    July 27, 2005 at 5:02 pm
    Sorry, should have posted:
    FCP4.5, QT6.something, IO drivers 1.3
    Alan
  • Alan Lacey
    August 2, 2005 at 5:45 am
    I’ll assume that this doesn’t work then?
    Alan
  • Daniel Fass
    August 8, 2005 at 9:58 pm
    I have been using the D9 with the Io for a few years now with no problems. The deck would not pass the audio to the Blackmagic Decklink but the IO works fine. You need the SDI board to do it.
  • Alan Lacey
    August 9, 2005 at 3:15 pm
    I do have the SDI board fitted but unfortunately it doesn’t support embedded audio, just separate AES/EBU. The IO EBU output is fine when fed to a Sony pro audio unit, but the JVC deck just wont see it.
    I remember a few years ago when I connected an early Fast 601 to the D9 (its a D750 BTW) the same thing happened. It worked fine with Sony’s EBU on Digibeta but not with the D750 until Fast rewrote the drivers.
    I assume the same thing’s happened here and that there is a slight difference between the JVC and Sony implimentation of the EBU spec.
    I’ve recently loaded Tiger and FCP5 so will can try the latest AJA drivers now.
    Alan
