Activity › Forums › Adobe After Effects › Invisible Text in After effects
  • Invisible Text in After effects
    Posted by Akhil Nair on August 4, 2020 at 10:56 am
    I am trying to paste some text in a language called Amharic. When i do that, in after effects it becomes invisible texts.When I type something else in English it works fine. The text is showing fine below in the timeline tab. I have installed all the necessary fonts.
    John Cuevas replied 6 years, 1 month ago 2 Members · 1 Reply
  • John Cuevas
    August 4, 2020 at 7:19 pm
    You text box indicates you are using Times New Roman, that font doesn’t have the correct glyphs you need to paste the text. Change your font to one that has the correct characters. You may need to use multiple fonts if it’s in English and Amharic.
    Johnny Cuevas, Editor
    ThinkCK
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
