Activity Forums Maxon Cinema 4D Invisible / Missing boundary box on Subdiv. Surface
  • Invisible / Missing boundary box on Subdiv. Surface
    Posted by Don Lavender on September 24, 2021 at 5:05 pm
    Good day. I’m following a tutorial from Eye Design in 2017
    EJ puts a cube inside a subdivision surface then manipulates boundary box points highlighted in blue in the bottom picture. When I put a cube into a subdivision surface there are no boundary box points just the points from Gourard Shading Lines.
    1) Could features have changes since then to R25. 2) Is there a setting turned off. I’ve attached two images. Thank you so much for your help.
    Don Lavender replied 4 years, 7 months ago 1 Member · 1 Reply
  • Don Lavender
    September 24, 2021 at 5:59 pm
    Solved. Under Options Check Filter then scroll to SDS cage. 🙂
