Invisible Frame on Timeline
Hello,
I have been editing together a selection of clips. I have used in and out points to edit these clips onto the timeline and also just dragged the entire clips to the timeline and cut out the section I need.
5 out of 11 of these clips have a ‘flash’ frame at the beginning on the edited clip. Meaning that when I play the clip a flash of the previous frame shows up but when I go through the clip frame by frame it is not there! I have zoomed in fully and still cannot see it. I have also cut the first bit off the clip and still the previous frame flashes on screen.
Anybody had this problem before, I have no idea how to get rid of this invisible flash frame.
Thank you
Stephanie Quilligan
