Activity Forums VEGAS Pro invisible borders in sony vegas 8
  • invisible borders in sony vegas 8
    Posted by Shaun Crocker on August 24, 2008 at 3:06 pm
    as you can see i seem to have an invisible border that i simply cannot remove, does anyone have any idea why it is there or how to get rid of it as it is spoiling all my video attempts, it also appears on the right hand side as well..any help is very appreciated 🙂
    Shaun Crocker replied 18 years ago 2 Members · 2 Replies
  • John Rofrano
    August 24, 2008 at 4:55 pm
    It looks like the aspect ratio of your video does not match the project. There are two ways to correct this. Set the project to match the video or crop the video to match the project. To match the video to the project, open Pan/Crop on the video event and right-click on the window that pops up and select Match Output Aspect. If that cuts out too much of your video then you need to undo that and set your project properties to match the dimensions of your video. The easiest way to do this to open the project properties (Alt+Enter) and then press the Match Media Settings folder (upper right) and select the media file to match to.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Shaun Crocker
    August 24, 2008 at 8:08 pm
    YES IT WORKED!! thank you so much!
