Activity › Forums › Zaxwerks › Invigorator Pro v5.0.0 won’t use Comp Camera
  • Invigorator Pro v5.0.0 won’t use Comp Camera
    Posted by Brian Charles on December 8, 2010 at 2:05 am
    I’m having a problem using Comp Cameras on Invigorator 5.0.0 layers.
    The setup looks fine but the moment I RAM preview or render the Active Camera view resets to the Invigorator Camera.
    Mac Pro 12 core, 32 GB RAM, ATI 5770, OS 10..6.5, After Effects CS4 (9.0.3.8)
    Brian Charles replied 15 years, 9 months ago 2 Members · 4 Replies
  • Edward Wu
    December 8, 2010 at 7:07 pm
    Hi Brian,
    You may have to uncheck and re-check the “Use Comp Camera” setting to reset the Camera data.
    There is an issue at the moment where the Comp Camera sometimes is not being used. We are working on resolving this issue and it will be fixed shortly. in the mean time, the workaround is to uncheck and re-check the “Use Comp Camera” setting to update the camera setting.
    Best,
    Edward
  • Brian Charles
    December 9, 2010 at 9:08 am
    So this is really a beta release…
  • Edward Wu
    December 10, 2010 at 12:32 am
    Hi Brian,
    We have resolved this issue now. We will be releasing a new version soon that will fix this issue. Unfortunately, it wasn’t happening on the systems that we were testing, so it took us a little while to track down.
    If you want, I can send you the new version while we are preparing to release the official 5.0.1 of the software.
    Best,
    Edward
  • Brian Charles
    December 10, 2010 at 1:09 am
    Many thanks for the offer Edward. I’ll wait for the official release.
