Activity Forums Adobe After Effects Invigorator HELP!!!!
  • Invigorator HELP!!!!
    Posted by Dori Minnis on August 8, 2005 at 3:02 pm
    Hey,
    I posted this in the Zaxwerks area, but no help… I really hope someone can help me or at least have some suggestions…
    I upgraded to AE 6.5 last week – and have had many problems. The latest problem is with Invigorator Pro. I am running OS 10.4.2 and Invigorator 4.0.5.
    While running AE 5.5 and Invigorator 4.0.4, had no problems. After the upgrade – when I try to change existing files, or creating new Invigorator files, I can no longer preview inside the Invigorator Options window. Here is an example of what happens… I create new solid, create 3D text, and the text shows up both in the composition as well as in the effects window. I then click on the Options menu (or the red button) – and the Invigorator window opens up. There is nothing but a blank screen. If I command-click to test – you can see the rendered sample, but there is no way to preview to change depth or anything else. I have tried re-installing everything… nothing…. This is so frustrating.
    Here is a sample of what the it looks like – in case I am not explaining well. In the window that I command-clicked to test render – I did nothing else… just to explain fully… I just opened – and command-clicked. Didn’t move the file. Basically – the file is there – but not visible. Please someone help!!!!
    https://www.22nd-st.com/help.jpg
    Thanks so much,
    dori minnis
    Manager Arts and Graphics
    Pittsburgh Penguins
    (412) 642-1841
    dminnis@pittsburghpenguins.com
    Serge Hamad replied 21 years ago 2 Members · 1 Reply
  • Serge Hamad
    August 8, 2005 at 4:52 pm
    Try reinstalling or upgrading your video card driver. Reducing the hardware acceleration may also help in your case.
    I hope this may help.
    Salut.
    Serge
