Activity Forums Zaxwerks Invigorator Crashing- Help!
  • Invigorator Crashing- Help!
    Posted by Ryan Zernec on March 27, 2006 at 11:34 pm
    I’m running After Effects 6.5, and I have a copy of Invigorator 3.0.2 and Illustrator CS. I can’t open my own created Illustrator files in my Invigorator, are they incompatible? Do I need a newer version of Invigorator? Whenever I try to open one of my files, I get a “Not Enough Memory” error. However, I was playing with the “Ring of the Cow” tutorial files, and those will open just fine.
    -Z
    Stormdave replied 20 years, 5 months ago 3 Members · 3 Replies
  • Serge Hamad
    March 28, 2006 at 12:05 am
    First I would advise you to upgrade your Invigorator version. 3.0.2 is way too old.
    I don’t think it can recognize illustrator files older then version 8. So just, save your ai file to this version and give it a try. But think about upgrading!
    Salut.
    Serge
  • Ryan Zernec
    March 28, 2006 at 1:29 am
    Thanks for the response. I tried this, but it still didn’t work. When I try to open the file in Invigorator it says “Not Enough Memory To Complete This Operation”, and if I try again it crashes completely. But for some reason it can open the “ring” files just fine, which were created in Illustrator 8 format.
  • Stormdave
    April 11, 2006 at 3:00 am
    I don’t know if that version has OpenGL support, but disable it if it does and make sure it’s on Software Only rendering option.
