Activity Forums Zaxwerks Invigorator Crashes
  • Invigorator Crashes
    Posted by Bob Rahfeldt on November 22, 2005 at 11:41 pm
    I’m having problems with invig crashing when i try to open the options palette in 3d invigorator. It happens pretty much everytime i work with it. It works fine the first time I open the options window, but everytime after that After Effects crashes. Any help would be appreciated.
    Bob
    Matt Rhodes replied 20 years, 10 months ago 2 Members · 1 Reply
  • Matt Rhodes
    November 23, 2005 at 1:20 am
    Hi Bob.
    Could you tell me:
    – Are you running Windows or OS X?
    – Which version of Invigorator are you using?
    – Are you using Invigorator Classic or Invigorator Pro?
    – Are you doing anything once inside the Set-Up window?
    If you’re getting repeatable crashes on a particular scene, would you
    mind sending it to me: matt@zaxwerks.com
    You can just send me the .aep file — no media files necessary.
    Let’s start with that.
    Thanks.
    Matt Rhodes
    Zaxwerks, Inc.
