Activity Forums Zaxwerks invigorator aspect ratio problem
  • invigorator aspect ratio problem
    Posted by Phil Biggs on November 14, 2005 at 8:55 pm
    I’m sure this has been discussed before although the search came up with no answers. My invigorator renders are being clipped off on both sides at the 4:3 limit when rendering a 16:9 comp. This problem is acknowledged on the Zaxwerks website but is not answered. Both the comp and the solid that invigorator is applied to are set to PAL widescreen but it seems that invigorator is stuck in 4:3. The problem can’t be seen in AE’s comp window – only on the renders.
    Anyone any thoughts? It seems a little backward to render out in 4:3 and then stretch it to 16:9 (working with circular logos) I’ve got a big deadline coming up fast so any suggestions will be appreciated.
    Cheers,
    Phil
    Matt Rhodes replied 20 years, 9 months ago 2 Members · 1 Reply
  • Matt Rhodes
    November 14, 2005 at 9:34 pm
    Hi Phil.
    I’d like to take a look at your file, if you don’t mind.
    You can send it (just the .aep file) to: matt@zaxwerks.com
    Also, could you tell me which version of AE and Invigorator you’re running?
    Also also, are you on Windows or Mac?
    Thanks.
    Matt Rhodes
    Zaxwerks, Inc.
