Activity Forums Zaxwerks Invigorator 4.0 user prefs
  • Invigorator 4.0 user prefs
    Posted by Yoondo on July 28, 2005 at 8:13 am
    Hello,
    I’d like to set the Y axis to “0” for the dupulicate offset.
    For some reason, it changes back to default (-50) after typing in 0 in the box.
    I clicked on save settings before hitting ok, but it still goes back to -50.
    This is annoying especially when I’m trying to create something like a fence.
    I’d appreciate it if someone could give me an answer to this.
    Thank you
    Yoondo replied 21 years, 1 month ago 3 Members · 6 Replies
  • Matt Rhodes
    July 28, 2005 at 3:54 pm
    Hi Dave.
    Which version (v4.0.?) are you using?
    Are you on the Mac or PC?
    I’ll take a look.
    Matt Rhodes
    Zaxwerks, Inc.
  • Serge Hamad
    July 29, 2005 at 12:25 am
    After typing in your new value, first hit Enter then save & hit Ok.
    Salut.
    Serge
  • Yoondo
    July 29, 2005 at 2:23 am
    Thanks for the reply Matt, I am using 4.0 pro on a PC.
    Thank you, Serge. I will try that first and let you know.
  • Yoondo
    July 30, 2005 at 1:49 am
    I got it to work by hitting enter on the main keyboard(I was hitting enter
    on the numeric key). However, I can’t save the settings as default even after
    hitting save.
    When I open the invigorator work window & go back to user prefs,
    it’s back to the original default 50, -50, 0.
    Thanks again.
  • Serge Hamad
    July 30, 2005 at 3:27 am
    Hi Dave,
    I would higly recomend you to download the latest version (4.0.5) of Invigorator Pro. This should take care of your problem and it’s free. I remember having your issue in an older version but I am fine with 4.0.5.
    Salut.
    Serge
  • Yoondo
    July 30, 2005 at 5:18 am
    Thank you very much, Serge. I will do as you suggest.
