Invig to ProAnim
Posted by Curtis on June 9, 2006 at 8:17 pmIs there a method for moving InvigPro scenes into ProAnimator?
Curtis
Jon Okerstrom replied 20 years, 2 months ago 2 Members · 2 Replies -
Jon Okerstrom
June 10, 2006 at 12:40 amHi Curtis,
You can move objects from Invigorator to ProAnimator and visa versa. In PA, you can use the object pop-up menu or object pull down menu>export 3D objects>choose all, selected or visible>use zxo format.
In invigorator, you can do the same using the object pop-up menu.
Then, in the other ap, use the object pop-up to import 3d object.
Does this help?
Jon
