Activity › Forums › Zaxwerks › Invig Pro 4.x Object Styles not included in the CS5 version
  • Invig Pro 4.x Object Styles not included in the CS5 version
    Posted by Curtis Jefferson on December 21, 2010 at 2:26 am
    My favorite object style for 3D text in the 32 bit version of Inv Pro is NOT in the 64 bit version. The text with a thin stroke on the inner diameter of the bevel with a thin stroke on the outer diameter of the bevel looked fantastic, but was omitted from the new version. This is very frustrating!
    Will you be adding more object styles in updates or is there a way to import styles from the 32 bit version into the 64 bit environment?
    Edward Wu replied 15 years, 9 months ago 2 Members · 1 Reply
  • Edward Wu
    December 21, 2010 at 5:44 pm
    Hi Curtis,
    If you have version 3D Invigorator PRO version 4.5.1, the swatches are placed in the “Documents > Zaxwerks > 3D Invigorator PRO” folder. You can copy the swatches from this folder, and place it into the “Documents > Zaxwerks > 3D Invigorator PRO AE5” folder. You can copy the “Material Swatches” and the “Object Styles” folder, and overwrite the swatches in the version 5 folder. This should give you both the version 4 and version 5 swatches.
    Best,
    Edward
