Activity Forums Zaxwerks Invig Prefs File
  • Invig Prefs File
    Posted by Jezzfush on May 23, 2007 at 6:06 am
    Hi, I keep getting this warning whenever I make changes in the Invigorator Pro setup window and exit. “unable to open zaxwerks invigorator prefs file for writing – settings may not be saved properly”. I am working on a Mac G5 Power PC and running Invigorator Pro v4.0.9
    It doesn’t seem to be causing any problems, just annoying.
    Any help would be appreciated. Cheers.
    Jon Okerstrom replied 19 years, 4 months ago 3 Members · 2 Replies
  • Matt Rhodes
    May 23, 2007 at 1:45 pm
    Hi JezzFush.
    It sounds like you don’t have write access to either the Invigorator Pref file or the folder that the Invigorator Prefs file is in.
    I would suggest doing the following:
    1. Open the folder where you have the Invigorator installed.
    (For AE 7, this is usually /Applications/Adobe After Effects 7.0/Plug-ins)
    2. Click on the folder containing the Invigorator plug-in.
    3. Press Cmd+I (Get Info).
    4. Check your permissions at the bottom of the Info dialog box. Make sure you have “Read & Write” access to the folder.
    If that looks correct, find the “Zaxwerks Invigorator Prefs” file in that same folder.
    Follow steps 3 and 4 to ensure you can read and write the Prefs file.
    Let us know if you have any questions.
    Matt Rhodes
    Zaxwerks, Inc.
  • Jon Okerstrom
    May 24, 2007 at 12:44 am
    Hi JezzFush,
    I would first suggest upgrading to the current version. 4.1.0 is available on the Zaxwerks website… it’s a free update.
    Jon
