Activity Forums Zaxwerks Invggorator closes AE HELP!!!
  • Invggorator closes AE HELP!!!
    Posted by Scott Boyd on November 28, 2005 at 10:39 am
    Hi all,
    A few weeks ago I place a post here about invgorator closing AE, Well I havent any luck fixing the problem yet so I will go into more detail about it,
    All was working very well until a few weeks a go , I just started a new project an stated Invig to import a new Illst. file. I click the setup up button then After effects just closed instantly.. No matter what I do It just keeps happening.
    I can get to the point where I have Invigorator running , I can move things around in the preview window but as soon as I click the red button AE closes ( If I click options in Invig AE also closes) Its driving me nuts!!
    I down loaded the newest demo of Invig Pro and the same thing happens.
    All other apps and plug ins seem to be ok
    I did remove and reinstall both AE abd Invg
    3.00 gigahertz Intel Pentium 4
    16 kilobyte primary memory cache
    1024 kilobyte secondary memory cache
    c: (NTFS on drive 0) 23.32 GB 9.38 GB free
    d: (NTFS on drive 0) 36.70 GB 15.58 GB free
    f: (NTFS on drive 2) 80.06 GB 77.70 GB free
    g: (NTFS on drive 1) 123.51 GB 61.67 GB free
    NVIDIA GeForce FX 5200 [Display adapter]
    Targa 15.7 [Monitor] (15.7″vis, September 2001)
    drive] (60.02 GB) — drive 0, s/n 3HR066TT, rev 3.05, SMART
    Pinnacle Systems DV500 E4
    Pinnacle Systems DV500 Overlay
    Realtek AC’97 Audio
    Adobe After Effects Version 5.5
    Adobe Illustrator Version 10.0 Build 76
    Adobe Premiere Version 6.
    Scott Boyd replied 20 years, 9 months ago 2 Members · 4 Replies
  • Matt Rhodes
    November 28, 2005 at 4:40 pm
    Hi Scott.
    Would you mind sending me your troublesome .aep file?
    I’d like to see if the problem occurs on this end.
    Please zip the file and email it to: matt@zaxwerks.com
    I only need the .aep file — no media files.
    Thanks.
    Matt Rhodes
    Zaxwerks, Inc.
  • Scott Boyd
    November 29, 2005 at 8:21 pm
    Hi Matt,
    There is not any particular file, it happens on all projcets enven new ones. I just cant get past the set up window with out the whole show closing down on meon me
  • Matt Rhodes
    December 1, 2005 at 12:59 am
    Hi Scott.
    Try the following:
    – Find the folder called “Zaxwerks Swatches”
    – Rename the folder to “Previous Swatches”
    – Try your scenes again. Note that you won’t see any swatches in the Swatch bins.
    If this works for you, please compress your “Previous Swatches” folder and email
    it to me: matt@zaxwerks.com
    If this doesn’t help the situation, delete the “Zaxwerks Swatches” folder
    that may have been created when you tried again — and then rename
    “Previous Swatches” to “Zaxwerks Swatches.”
    Let me know how things go.
    Matt Rhodes
    Zaxwerks, Inc.
  • Scott Boyd
    December 2, 2005 at 12:31 pm
    No luck, I tried that and it made no differance.
    Have youn any other Ideas, Cus I luv my Invig and i miss being able to use it
