Activity Forums Maxon Cinema 4D Inverting the Rotational Value of a Driver to the Driven
  • Inverting the Rotational Value of a Driver to the Driven
    Posted by Hayden Martin on September 25, 2014 at 5:54 pm
    Hi Guys
    I have a rigged robot set up, and everything is ok so far, but what I’m having trouble with is taking a rotational value of one shape, setting it as a driver, then having the driven represent the driver’s values but inverted:
    Driver = +90 Degrees
    Driven = -90 Degrees
    Sure it’s incredibly simple but I’m more familiar with AE expressions than C4D Xpresso…
    Cheers!
    Maxim Fischer replied 2 years, 7 months ago 3 Members · 2 Replies
  • Brian Jones
    September 25, 2014 at 6:24 pm
    open the xpresso and either set the Range Mapper/Output Upper to -360 or remove the Range Mapper entirely and place a Negate node (found in New Node/Xpresso/Calculate) in it’s place (connecting the in and out like the range mapper was)
  • Maxim Fischer
    January 23, 2024 at 11:59 pm
    Thank you Brian!😃
