Activity Forums Adobe After Effects “Inverting” a Shape Layer
  • “Inverting” a Shape Layer
    Posted by Eric Chard on December 5, 2019 at 12:36 am
    Shape Layers have a kind of implicit “mask” in that they are closed vector shapes, like a closed mask spline.
    Is there a way to invert this implicit shape? In the same fashion one would invert a mask?
    “Putting the HARM in ‘harmonica’ since 2005.”
    Max Haller replied 6 years, 9 months ago 3 Members · 2 Replies
  • Julien Schickel
    December 5, 2019 at 12:59 am
    I’m not sure of what you mean by invert? You want the shape to be a hole? If that’s that, you only have to create a solid (being your composition size), place it under your shape and use the track matte menu of your solid, with alpha.
    Julien Schickel
    Editor & motion designer
    https://www.youtube.com/channel/UC7_NVR3JLdhEYDlEQuNFfug
  • Max Haller
    December 5, 2019 at 7:54 pm
    Julien is right if you do it with a solid layer under the shape layer. You can also do it all in the shape layer by essentially doing the same thing except instead of making a solid layer, you make another shape path and use the merge paths with the mode set to subtract.
