Activity Forums Adobe Premiere Pro Inverting a 16mm Color Negative in Premiere
  • Inverting a 16mm Color Negative in Premiere
    Posted by Robert Hoffman on September 29, 2019 at 9:04 pm
    I’ve used my DSLR to digitize a film I shot on Kodak Vision 3 color negative film. What is the proper way to invert the film in Premiere to get a positive?
    Herb Sevush replied 6 years, 11 months ago 3 Members · 2 Replies
  • Chris Wright
    September 30, 2019 at 6:05 am
    if its an actual neg, you just use invert effect or flip the curves points opposite(or only bring them as far as they exist in the histogram)
    then color correct normally as below
    https://forums.creativecow.net/thread/394/394
  • Herb Sevush
    October 1, 2019 at 12:12 pm
    [Chris Wright] “if its an actual neg, you just use invert effect or flip the curves points opposite(or only bring them as far as they exist in the histogram)”
    If it’s a true film color negative this alone will not work, because you will have to account for the orange dye masking that was used to counteract deficiencies in the magenta and blue dies. This orange cast is visible when you handle most color negatives, still or motion.
    https://web.archive.org/web/20101128030127/https://photo.net/learn/orange-negative-mask
    Herb Sevush
    Zebra Productions
    nothin\’ attached to nothin\’
    \”Deciding the spine is the process of editing\” F. Bieberkopf
