Activity Forums Adobe After Effects Inverted Eyeball in video column.
  • Inverted Eyeball in video column.
    Posted by David Bliley on June 18, 2015 at 6:54 pm
    What does it mean?
    I’m working in a Digital Juice pre-made AE template and I’m trying to change the basic color of the template, but having a hard time figuring out exactly how this project is reading the layers. I’m wondering if the inverted eyeballs have something to do with it.
    Thanks for any help on this!
    david
    John Cuevas replied 11 years, 3 months ago 2 Members · 4 Replies
  • David Bliley
    June 18, 2015 at 10:37 pm
    Thanks for your response, Dave.
    See how some “eyes” are normal and others are… perhaps “negative” is a more appropriate term. I’m not sure what it means or what it’s really called.
  • David Bliley
    June 18, 2015 at 10:50 pm
    CC 2014
    There are a lot of effects in this project.
    Oh! But this is an old Digital Juice template… so I’m sure it was created in CS4 or something. Think that has something to do with it?
  • John Cuevas
    June 19, 2015 at 12:51 pm
    It shows that a blending mode, Preserve Underlying Transparency switch, and/or track matte is used by the layer.
    Johnny Cuevas, Editor
    ThinkCK
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • John Cuevas
    June 19, 2015 at 12:55 pm
    Often in template projects, many layers might be shied(as they generally aren’t needed), look to see if the guy looking over a wall button is pressed. You might not be seeing all the layers that are being used, so you should start there.
    Otherwise posting a screen grab of the final timeline will be very helpful in trying to determine where the background color information might be.
    ThinkCK
