Activity Forums Adobe Photoshop Inverted Clipping Mask / Knockout Mask…
  • Inverted Clipping Mask / Knockout Mask…
    Posted by Eric Barker on June 5, 2009 at 10:29 pm
    I’ve never had much use for clipping masks, it just seems much easier to create a layer mask, or if at all possible, a vector mask, instead. However, one thing I’ve always wondered is if there was any way to do a inverted clipping mask, or a “knockout mask”. I often need to have something like a rectangle of pixels with text in them knocked out (alpha’ed). Using just two layers: a shape layer and a text layer, is there any way of accomplishing this? In the past I’ve simply converted the text into a shape, and then used that to create a vector mask for the shape layer. But this can get combersomb after a while, is there anything more efficient?
    Television Producer
    KTVF-11 Fairbanks, Alaska
    video.ericbarker.com
    Juan Camilo Quintero replied 2 years, 4 months ago 3 Members · 2 Replies
  • Falk Franken
    March 13, 2019 at 6:07 pm
    In case anyone, like me, stumbles upon this because they have the same question. I just found the answer:
  • Place text above rectangle
  • Open Blending Options of text (by double clicking the layer or right click->blending options)
  • Under Advanced Blending you’ll find the “Knockout” option:
  • Set that to shallow (to knockout just the layer below)
  • or deep (to knockout everything until it reveals the background layer)
  • Reduce the fill opacity to 0%
  • done! Hope that can help someone 🙂
  • Juan Camilo Quintero
    March 14, 2024 at 1:32 pm
    This is HUGE! I have no idea what this webpage is but I just had to create an account just to reply to this.
    Thank you so much! 🙏🏼
  • We use anonymous cookies to give you the best experience we can.
