Activity › Forums › Adobe After Effects › Invert Tracking Data?
Posted by Collin Alexander on April 27, 2009 at 4:04 amHow do I invert tracking data in AE? In Motion you use “unstabilize”. Must be an easy way in AE.
I stabilized footage, then composited various things onto it. Now I need to unstabilize everything.
Thanks.
Collin Alexander replied 17 years, 4 months ago 3 Members · 5 Replies -
Peter O’connell
April 27, 2009 at 5:15 amHi, is it a 1 point stabilization or 2 (ie. scale and rotation keyframes as well)?
Peteroguekeyframe.com
Simon Bonner
April 27, 2009 at 7:16 pmYou should find these tutorials at videocopilot.net useful:
https://www.videocopilot.net/tutorials/demon_face_warp/
https://www.videocopilot.net/tutorials/stabilize_shaky_footage/
(The title of the first one may seem less relevant, but it deals with what you’re describing: stabilising a shot, adding effects etc, then taking away the stabilisation. The second tutorial shows how to stabilise a shot and then add back a little bit of the original shake so it still looks realistic).
Simon Bonner
youtube.com/simonsaysfx
Collin Alexander
April 27, 2009 at 11:10 pmIt’s a 2 point tracking, but not scale and rotation. It’s position and rotation. Scale stays constant.
Peter O’connell
April 27, 2009 at 11:29 pmHi, you can precomp everything (set the stabilized plate to ‘Guide Layer’ before precomposing) ,then make a few expressions between the flattened comp with your elements and the stabilized footage’s keyframes. Here is the basic gist of the expressions you need:
comped element’s Position = stabilized plate’s Anchor Point
comped element’s Anchor Point = stabilized plate’s Position
comped element’s Rotation = stabilized plate’s Rotation * -1If you use these expressions, the comped elements will integrate perfectly with the original plate.
Collin Alexander
April 28, 2009 at 1:00 amBrilliant, yes AK explains it well. His method worked right off.
Pre Comp. Expand the comp dimensions. Make a new comp. Copy the position data to anchor point, and anchor point data to position. Then copy rotation data to rotation, and multiply the expression by -1.
It works.
Thank you Simon.
