Activity Forums Apple Final Cut Pro Legacy Invert footage without double rotate
  • Invert footage without double rotate
    Posted by Stephen Lovett on March 11, 2010 at 8:36 pm
    I’m sure I’m missing something, but I’ve not uncovered a solution for what seems to me to be a fairly staight forward problem.
    Reasonably frequently I get footage from a Steadicam operator that is upside down, because due to time constraints on set, they just flip the camera over when they shoot in low mode.
    For dailies generation, the additional render time required created by the double rotate command in video effects menu is a real pain in the backside.
    given this particular 180 transform is pretty straight forward, I’m surprised that I haven’t been able to find a one step, less render speed impacting solution.
    What am I missing?
    Thanks in advance,
    Steve
    Terry Neilson replied 16 years, 6 months ago 2 Members · 3 Replies
  • Terry Neilson
    March 11, 2010 at 9:01 pm
    Effects>Filters>Perspective>Flop you get a choice of horizontal, vertical, or both
    moving parts are so last year
    MAC Pro quad 2.66, 8GB, XFX 4870, 23″ ACD, 10.6.2, FCS3, MXO2 Mini, etc.
  • Stephen Lovett
    March 11, 2010 at 9:53 pm
    Thanks much Terry,
    I’ll check and see if this shortens transcode time from the double rotate. I’ll bet it does
    Is there a way to set the default state of the flop filter to vertical?
    Thanks again,
    Steve
  • Terry Neilson
    March 11, 2010 at 11:47 pm
    Yes, apply the filter to a clip set to vertical and in the effects menu Set to Favourite, or optionF. Then apply it from the favourites bin. The settings stick.
