Activity › Forums › Adobe After Effects Expressions › Invert 1 Key Frame Value With A Checkbox?
Posted by Chad Gilmour on February 2, 2012 at 5:28 pmI couldn’t find an answer to this, but expression language is still pretty difficult for me to grasp.
I have 2 key frames and I want to be able to invert the value of the first keyframe by clicking a checkbox. The keyframes will never move along the timeline. I attached a still to help illustrate my question. I’m not very good with expressions and would really appreciate it if I got some help spelling this thing out.
Paul Roper replied 14 years, 7 months ago 2 Members · 6 Replies -
Paul Roper
February 2, 2012 at 6:15 pmPut this in your rotation expression:
if(effect("Reverse animation")("Checkbox")==1)
-value
else
value
Paul Roper
February 2, 2012 at 6:30 pm….although this will invert all your keyframes, unless you keyframe the invert control, ie. 1 frame before your second keyframe, set “Reverse Animation” checkbox to OFF, then on your second rotate keyframe, set it to ON.
Obviously there will be only 1 frame from inverted to positive; the movement will not be smooth. But that’s what you get with checkboxes – they’re either on or off.
Chad Gilmour
February 2, 2012 at 6:33 pmSweet! I got it to work by eliminating some of the carriage returns around “-value” and “value”.
I think this “if/else” type of expression might open me up to some new things.
Is there a place online that explains things like difference between using “( )” vs “[ ]” vs “{ }” and why you needed to use 2 equal signs instead of 1?
Thanks again, I really appreciate your help.
Chad Gilmour
February 2, 2012 at 6:41 pmMy second keyframe value is 0 so no checkbox keyframing required. Good to know though! Is there way to only select a specific keyframe with markers or something?
Paul Roper
February 2, 2012 at 7:38 pmDan Ebberts (you’ll see a LOT of him in this expressions forum!) has a great site:
As for the brackets:
() is normally used like you would in ordinary maths, eg. (2*3)+10 is not the same as 2*(3+10)….or as part of After Effects’ syntax of naming properties.
[] is normally used for arrays, eg. the position property has two or three variables: [x,y,z] so to access just the x, you’d use: transform.position[0]
to access the y, use
transform.position[1]{} are for Javascript-type things, such as if…then statements. In the example I provided, the {} isolate the different things, eg:
if (john_age > fred_age)
everything within
these curly brackets
happens if
john is older than fred
else
everything in here
happens
no matter
how long
it
rambles
on
for until you
get to the close
curly bracket
}Hope that helps…I’m just kinda rambling while my Mac has a prolonged spinny-ball-of-death moment. Ah – it’s back to life!
– Paul
Paul Roper
February 2, 2012 at 7:42 pm….oh and sometimes, when copying scripts from t’internet, it might help to first paste them into a text editor (TextEdit, Notepad, etc) and turn off all the formatting to get rid of any web/html/formatting weirdness, then copy from this and paste into after effects.
