Activity Forums Adobe After Effects Expressions Inverse Property Change
  • Inverse Property Change
    Posted by Corey Erickson on April 9, 2018 at 4:31 pm
    Okay,
    I’m new to writing expressions… I have done some super basic stuff and copy/pasted expressions I’ve found online.
    Question #1: What would be the best place to learn the language needed to write expressions in after effects?
    Question #2: I want to link the Scale of Object_A to the Scale of Object_B, BUT I want the Scale of Object_A to DECREASE as the Scale of Object_B INCREASES.
    Dan Ebberts replied 8 years, 4 months ago 3 Members · 2 Replies
  • Jacob Roth
    April 9, 2018 at 7:12 pm
    The best place for starting to learn how to write expressions is Dan Ebberts’ Motionscripts Mastering Expressions.
    https://www.motionscript.com/mastering-expressions/table-of-contents.html
    Dan also is a frequent poster here and can answer almost any expression related question you have.
    I also like School of Motion 30 Days of After Effects on YouTube, which have quite a few lessons that walk you through every step of using expressions to achieve a certain effect. Workbench is also a good resource on YouTube.
    As to your expression question, I’m new to expressions as well, so I’m looking forward to somebody, probably Dan, answering that question.
  • Dan Ebberts
    April 9, 2018 at 10:06 pm
    You could do it a number of ways, depending on exactly how you need it to work. One simple way, assumes both layers start at 100%:
    s = thisComp.layer(“Object_B”).scale;
    x = 10000/Math.max(s[0],.1);
    y = 10000/Math.max(s[1],.1);
    [x,y]
    It’s not likely this is exactly what you need, but you’ll need to provide more info if not.
    Dan
