Introduction to Lighting Passes Tutorial
Attention Cinema 4D Users:
It has been requested many times that I provide a demonstration on how to setup a project for Channel Lighting passes using Cinema 4D. So finally I have put together an introduction and tutorial on lighting passes, which are now available on my website.
For anyone that is interested, it would be great to get some feedback on the new tutorials. You can find them at the following location:
https://www.walkereffects.com/support/examples/
Cinema 4D Channel LightingYou need to have Cinema 4D 8.5 (9 should work, but I have not tested it there yet). You do not need a licensed version of Walker Effects to use the tutorials as the demo will work fine. Soon I will get to working on one for Maya as well. Also, I plan to write a much more extensive tutorial on render passes in general for both Cinema 4D and Maya.
Steven J. Walker
Walker Effects
steve@walkereffects.com
http://www.walkereffects.com———-
Dann Stubbs – dann@darkskydigital.com
Dark Sky Digital – https://www.darkskydigital.comhttps://www.RenderKing.com Value Priced Cinema 4D Render Farm
