Activity › Forums › Apple Final Cut Pro Legacy › Intra Frame Distance
Posted by Max Tremblay on March 12, 2014 at 2:11 pmI am curious to know what Intra Frame Distance (specifically 12) means and where I could find this information in a video file.
Ryan Holmes replied 12 years, 6 months ago 3 Members · 5 Replies -
Mark Suszko
March 12, 2014 at 3:27 pmI believe that’s how many frames in between “I” frames (versus “b” frames” in a video compression scheme .
Ryan Holmes
March 12, 2014 at 4:15 pmI-frame distance is a type of compression scheme, as Mark notes, consisting of I, P, and B frames.
I = Intra coded frame
P = Predicted picture
B = Bi-predictive or Bi-directional pictureThese options are set upon compression by adjusting the “Keyframe Distance” in your encoder of choice (Compressor, Media Encoder, Sorenson, Telestream, etc.). For a read through take look at Wikipedia:
https://en.wikipedia.org/wiki/Video_compression_picture_types
Ryan Holmes
http://www.ryanholmes.me
@CutColorPost -
Max Tremblay
March 12, 2014 at 8:08 pmI see. I received a video and need to figure out the distance between these frames, so how would I go about finding this information?
Ryan Holmes
March 12, 2014 at 11:13 pm[Max Tremblay] “so how would I go about finding this information?”
Out of curiosity, why would need this information?
Typically people set it to half the frame rate. So if it’s a 30fps, typically people set the keyframe at 15; if it’s 24 people set the keyframe at 12. At least that’s standard practice for how I typically encode…unless you have really fast motion sequences then I may shorten the distance between I-frames.
Ryan Holmes
@CutColorPost
