Activity Forums Apple Final Cut Pro Legacy Interview of 2 people
  • Interview of 2 people
    Posted by Jim Reed on November 24, 2014 at 4:51 pm
    I need to make a video that has two different people on two separate cameras views.
    When I get both videos on the timeline you can only hear audio from the selected video. I need this to run so when one person stops talking, you can hear the next person talking. I have a split screen set up, but I need help on getting the audio fixed.
    Jim Reed replied 11 years, 9 months ago 4 Members · 5 Replies
  • Mark Suszko
    November 24, 2014 at 5:55 pm
    Can you show a screen grab of your timeline?
  • Jim Reed
    November 24, 2014 at 6:06 pm
    What is a grab?
  • Shane Ross
    November 24, 2014 at 7:12 pm
    Make more audio tracks. Have at least 4. Two for the first interview…so A1 and A2. And then two for the other interview…A3 and A4. This way you can layer the audio if you want.
    Shane
    Little Frog Post
  • John Rofrano
    November 24, 2014 at 7:14 pm
    [Jim Reed] “What is a grab?”
    A capture of your screen so that we can see your timeline. Use Command + Shift + 3 to create a copy of your screen as an image on your desktop. Then upload that image and add it to your post using the Image Upload button above where you are typing:
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Jim Reed
    November 24, 2014 at 7:16 pm
    [Shane Ross] “Make more audio tracks. Have at least 4. Two for the first interview…so A1 and A2. And then two for the other interview…A3 and A4. This way you can layer the audio if you want.”
    That did the trick. Plays perfect.
    Thank you all very much.
