Activity Forums Adobe Audition Interview Compression
  • Interview Compression
    Posted by Pavlos Varnavides on November 26, 2008 at 6:13 pm
    Hi there. Adobe Audition newbie try to make an interview sound nice!!
    2 voices on the track, one regularly hitting -2 db, the other regularly hitting -10 db
    Thats my problem – one voice much louder than the other – probably due to proximity to microphone.
    Tried multiband compressor which helps to a point, but still voice two isnt quite loud enough and I now have quite a lot of background noise / hiss on it.
    Any help here fro the hardcore audition heads?
    Thanks!!!
    Pavlos Varnavides replied 17 years, 9 months ago 2 Members · 4 Replies
  • Emmett Andrews
    November 26, 2008 at 7:25 pm
    just highlight each of the parts for the second voice and normalize to -2dB.
  • Pavlos Varnavides
    November 26, 2008 at 9:59 pm
    thanks emmett.
    problem there is its a LONG interview so would take quite a while, and lifting the voice is giving me lots of background noise…
  • Emmett Andrews
    November 27, 2008 at 4:56 am
    There are a number of third-party plug-ins that will do this. And Soundbooth has a utility as well. You may need to run some noise reduction.
  • Pavlos Varnavides
    December 1, 2008 at 10:05 pm
    I ended up using Levelator and stuck it through some noise reduction. Results were more than acceptible.
    Thanks again for your help.
