Forums Adobe Audition Interview Audio Clean up
  • Interview Audio Clean up
     willie toth updated 14 years, 5 months ago 2 Members · 4 Posts
  • MarkofCain
    August 10, 2006 at 2:45 pm
    My most recent interview has some audio issues that I need to address before the video is ready for the public.
    Problems:
    1) fairly constanct background noise
    2) target voice needs to be brought out or “brighter”
    Here are two links for a segment of the interview.
    1) original file:
    https://www.southshorechurch.com/media/interview_original.mp3
    2) Same file with background noise pulled out
    https://www.southshorechurch.com/media/interview_background_noise_removed.mp3
    What do I need to do to make this a better quality audio?
    Thanks in advance.
    Mark Cain
    Sarasota, FL USA
  • willie toth
    August 10, 2006 at 9:03 pm
    Mark,
    Bring your file into the edit side highlight a small section of JUST THE BACKGROUND NOISE go the EFFECTS > NOISE REDUCTION > NOISE REDUCTION > OK now highlight the whole clip and go to the noise reduction again and preview (it will be open with the last setting used) … You will have to adjust the percentage of reduction, if you take too much out at one time it gets ugly, moocho ugly, I fondly refer to this as the “rain barrel effect” not good Grasshopper … WILLIE
  • MarkofCain
    August 10, 2006 at 9:32 pm
    Thanks for the input — but perhaps I wasn’t clear — I’ve already done that. That explains the two differnt files:
    “original”
    and “Same file with background noise pulled out.”
    I posted both files so that you could see that I didn’t destroy the file by removing the constant background.
    Let me restated my question — Now, since I have pulled the background noise out, what is my next step to make the target voice “brighter” / “stand out more?”
    Are you saying that I didn’t pull enough of the background out?
    Thanks for your patience and help.
    Mark Cain
    Sarasota, FL USA
  • willie toth
    August 10, 2006 at 10:19 pm
    Mark,
    Give this a try … Using the PARAMETRIC EQ I would pull some mids out this will thinkin things up a bit, then I would do a hard limit … Keep the default settings with the exception of MAX AMPLITUDE, I would set that to -1db …
Viewing 1 - 4 of 4 posts
Log in to reply.
