Activity Forums Adobe After Effects Intersecting lines/objects: making intersection ‘soft’? (fillets? chamfers?)
  • Intersecting lines/objects: making intersection ‘soft’? (fillets? chamfers?)
    Posted by Eric Chard on September 20, 2013 at 10:11 pm
    Imagine you’ve created two boxes or thick lines in two different Shape Layers (although it could be anything– footage, text, whathaveyou). One horizontal, one vertical.
    How would one make the INTERSECTION of these two layers ‘soft’, that is, not right angled? A nice curved fillet or chamfer? And have the intersection stay ‘soft’ even as the layers moved about?
    “Putting the HARM in ‘harmonica’ since 2005.”
    Darby Edelen replied 13 years ago 3 Members · 3 Replies
  • Kevin Camp
    September 21, 2013 at 9:02 pm
    The only way I can think or would also round all the corners. If your cool with that, then give this a try.
    Make an adjustment layer above the alpha layers and add a blur effect (fast blur, gaussian, etc) and set a blur amount. Then add a levels effect and tighten up the alpha levels so the soft edges get sharp.
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Eric Chard
    September 22, 2013 at 6:37 am
    I’ll give that a try, Kevin, thanks.
    To describe it ‘better’ (or at least more), what I’m attempting is almost a ‘metaball’ effect, but only in 2d, where the lines have a sort of illusion of surface tension.
  • Darby Edelen
    September 23, 2013 at 4:29 pm
    Kevin’s approach is a great one. Another good option is to use the Median effect. Unfortunately Median runs quite slowly.
    Darby Edelen
