Activity Forums Adobe After Effects Interpreting PAL/DV/25i fields correctly
  • Interpreting PAL/DV/25i fields correctly
    Posted by Darren Edwards on April 10, 2007 at 1:32 pm
    My question relates to the following project type:
    PAL/25FPS interlaced/16:9/DVCAM
    AE ver.6.5
    NLE: PPro 1.5.1
    Theoretically, importing 25i footage into AE, applying
    effects, telling AE to interpret the footage ‘lower
    (or upper) fields first, and then rendering out shouldn’t
    be a problem. After extensive efforts, we’re still (this
    question was briefly answered here once before with:
    ‘select interpret lower fields first’) finding anomalous
    green lines in the post-AE footage.
    Is there a Project Setting box I’m missing which should
    be ticked or unticked, etc.? A school-boy error I should
    be ashamed of?
    Occasionally it won’t happen, but then, as soon an aston
    (or any type of motion graphic) is applied to the footage,
    it’s back.
    Working with interlaced DVCAM footage is torture enough, so
    any help appreciated.
    Cheers in advance.
    Your chump,
    Darren.
    x-gf.com
    Darren Edwards replied 19 years, 5 months ago 14,384 Members · 3 Replies
  • Darren Edwards
    April 10, 2007 at 3:28 pm
    I understand Dave, but we’re talking about uncompressed DVAVI
    footage being bumped back and forth Premiere and After Effects.
    It makes a mockery of Adobe’s so-called seemless workflow,
    don’t you think?
    Darren.
    x-gf.com
  • Darren Edwards
    April 10, 2007 at 4:01 pm
    Dave, I’ve used AE, Magic Bullet, Sapphire, blabla to grade, pulldown
    everything from digitized Super-8 to 4.4.4 HD, over the years; the nub
    I’m trying to get too is, as I’ve only experienced this bizarre field
    issue with PAL 25fps/interlaced footage on a Premiere Pro/After Effects
    workstation, is it an issue localised to this format, that’s all. Maybe
    fellow UK-based editors have experienced it too?
    Darren.
    x-gf.com
  • Darren Edwards
    April 11, 2007 at 10:13 am
    Dave,
    Apology accepted. Sadly, I’m now old enough to say that ‘I’ve been around
    for a while’ in this business. – The BBCi channel I was head of production for
    a year even won a RTS (Royal Television Society) award (Innovative Idea of
    the Year 2005), although, none of my team were invited to the ceremony.
    The swines.
    Anyhoots, what I mean by ‘uncompressed’ DV is a local term I/we use for DVCAM
    rushes on the timeline which hasn’t been affected in any way, that’s all. It
    kind of keeps things simplified if the final product ends up transcoded into
    a million different formats.
    Experimenting with AE’s field interpretation settings did affect things slightly.
    The field defaults in AE and PPro (in PAL projects in the UK, at least) are matched
    anyway, so when I first started using our PPro/AE workstation a few years ago
    I didn’t notice the lines at first, because I wasn’t expecting to see them
    there. It was only when we upgraded AE and PPro with Magic Bullet, graded a
    project (pop video) with some dark greens in PPro, that they were spotted…
    Then this ‘oh shit’ panic of: ‘How many projects have left the building
    with these noticable lines on them?’ kick in.
    (Reluctantly) deinterlacing helps, but not much. Twiddling with the interp settings
    within PPro and AE worked, then didn’t, once motion graphics and/or plugins were
    introduced. I probably need to poke a tech guy over at the Adobe forums, really, but I’m
    usually too busy, and more fortunately, interlaced DVCAM projects now amount
    to about 10% of what we do; it’s just one of those bugs I’d like sorted on
    principle more than anything else.
    We’ve upgraded the PC suite with PPro2 and AE7 but the plugins haven’t been
    installed in them yet so they haven’t been used.
    Thanks again, though, for your repeated attempts to help.
    Darren.
    x-gf.com
