Activity Forums Adobe Premiere Pro interpreting footage, over-cranking & CS4
  • interpreting footage, over-cranking & CS4
    Posted by Josh Figatner on January 25, 2010 at 5:27 pm
    Hello everyone, I have a quick question regarding nice smooth slo-mo footage & CS4 (Windows Vista 64bit):
    I have an HPX170 (great camera) and I’m toying with over & undercranking footage and I’ve noticed that when I shoot in 24PN mode at 60fps, I get great smooth slo-mo footage on a 24P Premiere Sequence. However, when I shoot 720p60 in the camera and interpret the footage to play back at 24fps in CS4 in the same sequence, I can see frame blending upon playback. Shouldn’t this technically produce the same results? I also tried importing the clip at its normal 60fps and just slowed it down using the ‘speed’ function in premiere but same problem.
    Sometimes you want to have a clip play slo-mo but didn’t have the camera set up in ‘overcrank mode’ when shooting. I guess I just want it both ways…
    Josh Figatner replied 16 years, 7 months ago 2 Members · 2 Replies
  • Vince Becquiot
    January 25, 2010 at 8:16 pm
    The trick is actually to disable frame blending for slow motion clips.
    Vince Becquiot
    Kaptis Studios
    San Francisco – Bay Area
  • Josh Figatner
    January 25, 2010 at 8:23 pm
    Nice, I’ll give it a shot. Thank you!
